I swapped a mark 8 tranny into my 95 lx and I used the speedo gear from the 98 tranny too. Is this correct? I have 3.08's in the 95, so what would the correct speedo gear be for the 98 output shaft?
-Thomas
Use whatever speedo gear the Tbird had in it. The Mark 8 tranny should be the same as the tbird's original tranny.
that may explain why my odometer reads 400mi when I've gone about 300mi lol.
I thought the 98 mark's all came with 3.08 gears also?
And I also thought the output shafts were different between 95 and 98?
Yep, that explains it. The output shafts are the same on Marks, but stangs got 8 tooth speedo gears while the tbirds got 7 teeth. The rear axle ratio on the mark really isnt important, if you get the output shaft and VSS teeth right the car will shift just fine.
I asked about the rear dif on mark's because I used the speedo gear from the 98 mark. So I need to swap in the old one from my 95 tranny? They were different colors.
-Thomas
Marks have either 3.07's or 3.27's in the LSC. I don't know for sure if the Mark tranny has a 7 or 8 tooth drive gear however. My guess is that it is the same so you should use the tan driven gear if you have 3.27's. This is speculation though...
