i have a line on a 6 psi vortec kit. it is from a 99 gt. i looked through the instructions briefly and the only difference seemd to be that the 96-96 came with an fmu and t rex pump. the 99 kit has a chip and injectors. is there any other difference? we took the mounting bracket and checked it agianst my engine and it looked like everything mounts up. is this kit a direct bolt on to my car? or will it not fit at all?
ok well i just compared the parts list for both the 99 kit and the 96-97 kit. the 99 kit came with injectors, pump assembly, and a chip. the 97 kit has the fmu and t rex pump. one or two nuts/bolts are different. the mounting bracket assembly has a different number, but all components are the same. i sent vortec an e mail so i will see what they say.
Overkill Fetish Freak
By law they will say they do not make a kit for the MN12's. The FMU and T-REX are ghey anyway and best left out of the picture. Just get a '96-7 tuners kit and slap it on and add a better inline pump like the Bosch one here.
Did you give up on the turbo setup already? :rolleyes:
