1 - 15 of 15 Posts
I remember that from years ago, in stock form the engine should be rather healthy, figure a stock 90 makes 235 crank hp, that low end torque must be a beast in an aero
The LS1 idea is a much more reliable setup, Ive personally known folks to put over 200k miles on LS engines with never having the valve covers or oil pan off, a stock LS1 will put down about 370 crank hp with slightly less bottom end tq
Gotta love those guys who enjoy a little experimental adventure now and then.
Rather disappointed however that he didn't post performance figures. I imagine that thing should cruise north of 140 knots easily. With that FI engine, his ceiling is probably closer to 16,000 feet than 6,000. :)
Edit: Yup, according to another article, its top speed is 160 knots... :)
As far as planes go, apparently this BD4 has a pretty high glide ratio (compared to say, a combat fighter or a 747).
I would still rather be on the ground when my engine craps out though.,
-g
In this application SC is better than LS by far. Forced induction.
Absolutely. Smaller/lighter is better as well.
I'd want one of the new Ecoboost 2300's and a turbo; that's really impressive.
ENGINE TYPE: turbocharged and intercooled DOHC 16-valve inline-4, aluminum block and head, direct fuel injection
Displacement: 140 cu in, 2300 cc
Power (est): 305 hp @ 5500 rpm
Torque (est): 300 lb-ft @ 2500 rpm
Much lighter than any of the others. :D
I've heard the 1.0l ecoboost can do 250hp with a blower... :)
Pretty cool project. Sure hope he did the HGs before one blows him out of the sky. Am I the only crazy nut here that would STILL put a high-compression high-revving RPM monster in there instead of FI? :D
Oh and all that work, and he couldn't ceramic/thermal-coat the headers! PFT! Amateur! :cool:
High compression won't do too much for you at 18,000 feet, where the static air pressure is less than half that of sea level... ;)
which is what will allow me to run 30:1 static CR. :D
28 cylinder, turbo-supercharged, 4300 HP, 71.5L wasp, .....
or nothing. :D
<img src="http://www.nationalmuseum.af.mil/shared/media/photodb/photos/061016-F-1234S-002.jpg" width="800"/>
Will that clear a stock hood?
:rofl:
1 - 15 of 15 Posts
