Is there any place where I can find a bigger pin to retrofit into the hinges on the door to fix the sag. It's just an idea and may not work but I thought maybe if I could find a bigger pin and bore out the hinges slightly it would be stronger and not start sagging again in a couple years. If not, where is the cheapest place to get hinges. I can't find the hinge kit at spinningwheels-sc.com. Maybe I'm just not looking good enough.
I think the F150 pin is stouter... seems there was a thread around about using those.
Check the technical articles, there is an article about using the F150 Pins
How about some kind of bushing, like they use in the rebuild kits for the early mustangs? They mustangs use a bronze bushing so there is no steel against steel wear. just a thought. does anyone have the diamete rof the pin on the later birds? i can look it up in a supply catalog and see if bushing to fit are available..
There was a post I did prob last summer, that I had posted the part numbers and the cost to fix a sagging door on a tbird I had. The cost of the parts was under 10$.
The post I had also had the sizes iirc, measured with a caliper.
The kit was 1 pin and 2 bronze bushings, it took 2 kits to do my driver's door.
