I've read quite a few of the A/C threads here, and am not entirely sure that I was able to find exactly what I am looking for - and I admit to not knowing a lot about automotive A/C. So please bear with me, thanks.
I have a '97 T-Bird with the 4.6L V-8. The A/C isn't putting out cold air, but here is some information that I hope can be used to point me in the right direction:
The compressor is turning, and the clutch is engaging/disengaging. It seems to spend 2-3 seconds cycling, and 7-8 seconds not cycling.
AFAIK, every selector switch for redirecting air - be it out the dash vents, the floor, the windshield, etc. seems to work fine.
The engine RPMs go up and down (which I believe is normal) when the A/C is cycling and not cycling.
I can definitely get hot air by increasing the temperature.
With the A/C on for a few minutes, one of the lines in the engine compartment does get *very* cold to the touch and even has condensation on it, which tells me that R-134 is in the system and flowing- I think, if you are looking at the firewall when standing in front of the car with the hood up, it's the right-side line. However, I do not see any condensation dripping from under the car.
With either the regular outside air or with the A/C on, the air temp flowing into the car seems to be the same when I sent the digital temperature to 60 degrees (the coldest setting I can get).
It almost seems like I am getting R-134 flowing through the system, but am not getting any air to pull across the evaporater core? Would this be a door inside the ducts that may be stuck or binding?
I have not tried getting any fault codes, etc.
Any ideas or assistance would be greatly appreciated. Thanks.
