My compressor is seized causing slippin of my belt and it's causing some problems. Would it be easier to buy a delete bracket or just get a shorter belt?
Prob just getting a shorter belt but very soon if you continue it will make the choice to stop working for you. Obviously it's not going to last very long slipping like that. It would be a cleaner look in the long run to take the entire compressor out if your not going to have the a/c fixed.
There is a thread here somewhere with the shorter belt going in reverse around one of the idlers is able to bypass the A/C until you get the new compressor. I did it myself for about 6 months when mine went bad.
