See the disclaimer (red box text) on this product?
Does that apply to our cars, i.e., you can't go by pressure?
That's the point: the disclaimer reads that some vehicles with an expansion valve cannot be accurately filled by using the pressure reading.No, our cars have an expansion valve.
So then, what options do I have?Our cars use an orifice tube, not an expansion valve. But yes those cans are junk, you’re putting air into the system through the hose
Typically when people top off with the can, it works great for a season and then next year same problem.So then, what options do I have?
My A/C functions, but it's not very cold.
The right way to do it is to have the system fully evacuated and the have the correct amount of weighed refrigerant put back in, eg take it to a shop.So then, what options do I have?
its still not going to be a truly accurate charge
I mean if you "top it off", there's no way of knowing how much refrigerant is left in the system to know how much weight to put in from the 12oz can(s). Doing it the right the system needs to be fully evacuated, legally and ethically requiring a visit to a shop to pull it one way or another, from there you can do it yourself using all that stuff to refill after finding/repairing the leak source.
Correct. See post #7. Topping off a leaking system won't make a difference in charge amount when its going to come back out anyways - it only verifies that the system is leaking and then the moral / legal obligation is to have it repaired. This only applies if you have the Section 608 ( Types 1-3 ) or Section 609 ( mobile ) certifications. 😉I mean if you "top it off", there's no way of knowing how much refrigerant is left in the system to know how much weight to put in from the 12oz can(s). Doing it the right the system needs to be fully evacuated, legally and ethically requiring a visit to a shop to pull it one way or another, from there you can do it yourself using all that stuff to refill after finding/repairing the leak source.
I apologize I did mean to say orifice tube.Our cars use an orifice tube, not an expansion valve. But yes those cans are junk, you’re putting air into the system through the hose
Ok, I gave this a try. Bought a 12 oz. can without sealer and bought a hose with pressure gauge.When the performance was weak in 2019 I added a can and its been nice and cold since.
You should have at least seen pressure changes when the AC compressor kicks on and off.. Problem was: the pressure never changed; it always stayed at 30 psi.
The compressor was running continuously.You should have at least seen pressure changes when the AC compressor kicks on and off.
Yes. Similar.This kind of hose/gauge?
