My upper control arms need to be replaced, the rubber boot on both of them is split.
They Look like the one from Chlorine's Post HERE
I was just making sure this is the correct parts before i order them...they are...
MOOG Part K8596 (Frt Susp; Upper;LH 1 Required {Control Arm w/ Ball Joing}) for 53.79
MOOG Part K8596 (Frt Susp; Upper;RH 1 Required {Control Arm w/ Ball Joing}) for 53.79
from Rockauto.com
Are these the correct parts to fix this problem and if so, doesn any know any other place that has them for these cheap or cheaper?> THANKS
Also, does anyone know where I can get an Oxygen Sensor that is relatively cheap? THanks
Yeah im positive those are the right #'s I just replaced mine..but I paid 70+ea for mine at discount :(
just picked myself up a set last week paid $56 and some change for each.(MOOG)
but for my RIGHT side the number is 5898 not 5896 and it came with a grease fitting on it.
Cougar Pilot
This is what I had stored on my computer as far as that goes:
Upper Control Arms w/Ball Joints - Moog P/N K80053 and K80055 $50 ea.
https://www.rockauto.com/applet.html
Info from TCCoA forums, not too long ago. I don't know why our part numbers don't "jive" :confused:
Hey gary type in this code 7553684909 in the part were it asks were you heard about them you get a 5% discount on stuff
