I sent my injectors away to a place called witchhunter.com. The cost was resonable at $12.00 per. I got a chart back showing before and after. All the injectors clean up well. The chart showed 3 injectors were flowing 15%-20 less than the others. After the cleaning they all flowed within 2 points of each other and the base was raised as well. Also, you get new o rings and bottom thingie covers (very technical) and get all the old parts back. The owners name is Gordon. I am pleased with the results.
Check it out.
MaleWhore
i know a place here in MI...CPR is right around the corner...does that help? :D
Fry Rice Specialist
where is it and price range?
A can of denatured alcohol in a full tank of gas has always worked for me.
MaleWhore
Nabeel casper...that guy with the red AED birdy at the meets does it...
