My Engibe light came on and was on untill i did a huge burn out. I held it at 5.5K rpm for about 20 seconmds and let off. then about 10 seconds latter the engine lite was off. I still hav a stight backfire while going up hills in overdrive below 2000 rpms. Any thoughts? Eric
I had a similar problem. I cleaned the MAF (no luck) chaned plugs and wires (no luck) changed the coil packs (no luck) changed fuel filter (no luck) changed fuel pump (no luck) so I ordered FRPP 19 lb injectors (man are they alot bigger than stock (fatter) and now she runs like a dream. My first hard push I spun through first and halfway through second. So take your pick on what you want to do but depending on the miles that you have on your car all of these need to be looked at.
Chuck
