1 - 20 of 21 Posts
Greetings, y'all.
So for the couple years I've owned my car, it wasn't until tonight I noticed a small white sticker on the driver's side door jamb that reads: "Calibration" followed by some other letters and numbers. Any idea why that would be there?It's a 94 4.6 xr7. Thanks y'all!
u sure?.........i thought it was for the tranny........i know that my pcm was reprogrammed and i have the sticker on my car w/ some calibration number as well....
ShadowDragon said:
Well he didn't say what the numbers are but yes if the odometer was changed it would have to be indicated.
It's a different sticker, much smaller than the one that would indicate when the odometer was changed, if it's the one I'm thinking of. My car has it, and I would think all had them.
not a very good pic 'cause i was takin it 'cause of the hinges, but here's a little bit of what mine looks like if you can make it out.....
<img src="http://members.tccoa.com/94birdnj/hinge/st3.jpg">
Discussion Starter · #6 ·
Well if the speedo was swapped and adjusted to the correct miles, a sticker with the old miles would be unnecessary. :) but I think it'd still be required.. Anyway... the number on the sticker isn't miles.
Yea, that's the sticker in the picture. Thanks
Just random curiousity... Thanks, y'all. :)
Sheepish
Mine has one of those stickers too. Isn't that where they calibrated it at the factory?
*cough cough* I wouldn't know anyone who would do that *cough cough*
As I'm sure you know 145mph isn't stock for the LX/XR7 ;)
Sheepish
Must you keep rubbing yuor fancy pantsy SC speedo in my face ShadowDragon? ;) One of these days, I'll have one of my own. One of these days...
That code is needed by ford when you get emission control parts from them. When i got my IAC the guy needed that code to get me the right one. They said that if i need any emission parts like EGR, IAC, and bunch of other stuff, they need that code.
well i know for a fact that the PCM's were recallibrated to fix some stuttering and shifting issues w/ the transmission.........not sure what calibration number i have 'cause it's midnight around here, but i'll check the tsb and my calibration number and if they're the same then that's probably it.
Now I just need to figure out how to safely get a picture of it while it's pegged... :D
Sheepish
Put the rear end up on about 3 pairs of jack stands, gingerly get into it, start it up, and run it until its pegged? 145MPH in place must be scary. :)
Although if you had a friend that worked at someplace like discount tire that has a true FRAME lift. You know, that doesn't touch the wheels but still lifts the car, that would be ideal. But only do it if you'ev got a Mk VIII driveshaft in there buddy. Would hate to see your car ripped to shreds. Then you'd just have to send me your whole guage cluster. ;)
Um.. I was thinking more along the lines of on a dyno. ;)
Good thing is with my 3.08s I'd only need to be at 4000rpm in OD to make 145mph.
So I'd need a new driveshaft but the TC would still be ok.
http://www.302cobra.com/stuff/topspeed.html
Tire info 205/70r15 (for a few more weeks)
Rear End Ration 3.08
4R70W gear ratios
1 2.84
2 1.55
3 1.00
4 0.70
hey guys.......it indeed is the calibration that your PCM has......
<img src="http://members.tccoa.com/94birdnj/calibration.gif">
here's a cleaner pic of mine. 4-18B-R05. that's what was on there when i got the car, but under the hood there's a ford sticker saying that it was updated per this TSB
http://www.mn12performance.com/mn12-techinfo/tsb/tsb-95-8-3.pdf
I have one too. I know my engine was once replaced because of the sticker that used to be on the engine. Maybe that was around the time they did some re-calibrating to it. But I was hanging with another tbirder the other day and he had one too. That was the first time I really noticed mine and the first time he noticed his. We thought it was something from the factory.
-Shawn
This is what it is
I have a sticker under my hood saying my PCM was reprogrammed.. I also have that calibration sticker on the door, like in the pick above.
My speedo broke and then I had ford fix it. This is when they put that calibration sticker on the door jam.
Like i said before,
This comes on all cars and it has to do with emission stuff. This was straight from Ford. Like there are 2 IAC's that come up in ford system and they can tell what one you need from that sticker. So it has nothing to do with changing the speedo or reprogramming the PCM. Its on every thunderbird. At least on all the 96 birds.
1 - 20 of 21 Posts
