Wondering if i can use non abs axles in my car which has abs. And if so will the rear abs just not work or what will happen.
Hmmm....Wont the non ABS shaft clash with the Hub.
so they will fit then but will my car be messed up or the abs light will just be on
I think everything has been said in this thread. The abs and/or traction control will not work if you do not have the toner rings for them. They will fit, they just won't work completely correct.
Alan
if you want to feel what your car would be like without abs pull the high current fuse and turn off the traction control. Thats what its going to be like without the rings..except the front might still work? Idunno?
