G
Guest
·Alright, the car was in an accident (hit a deer) and I've fixed everything except for the airbag ground problem and the ABS... I'm trying to fix the ABS right now and Every time I put the fuse in for the ABS Pump the pump will continuously run and when you depress the brake pedal... it pushes the pedal right back up... I have no clue what's wrong, any ideas? I've replaced the ABS computer with one that is good and that's all I've done.
