the ac pump on my 90' Cougar has frozen up... is there a cheap way I can bipass the pump by re-routing the belt? Or is there a way I could stop the pump from locking up?
1989 Thunderbird V6 was able without A/C. Through your local dealer, or any Ford / Motorcraft parts distributor, you should still be able to order the idler pulley / bracket assy. that was bolted in place of the A/C compressor on those cars. Don't remember the number for sure off the top of my head, I'm going to guess at E9SZ 8678 A, maybe B. I can check it out tomorrow at work if you like.
cheers
Ed N.
i just did the smog and ac delete if you would like i could post the belt size i used cost like $22 at bumper to bumper.
How much do the delete pulleys cost? This is my beater car... would the shorter belt work just as well?
no smog setup on the 3.8s :) the belt sizes are probably different too.
thomas did an a/c delete, but his belt is even shorter cuz i think he has bypassed another pulley too. i want to say it was an idler pulley that was bypassed.
stoltz, i can sell you my a/c compressor if you want.
Full Metal
or i could sell you my compressor, it's already off the vehicle, i bought if off of someone on the boards and never used it, and my 92 is gone so i don't need it anymore.
The A/C delete pulley and bracket is E9SZ 8678 C, Motorcraft YS-174. Wholesale price is $70.26 up here in Canada, so maybe ~$50 in the U.S. This would go in place of the compressor, and keep the original belt.
cheers
Ed N.
