I am having some issues with my bird and i need some help. I was just driving at about 40 mph and all of a sudden my floor and defrost vents kicked on full blast with outside temp air. nothing on my auto climate control unit display and the high/low/auto knob does nothing. the position selector ( vent, floor def, etc) will change where the air comes out, but the off position still shoots air full bast. i cannot adjust the air temp either. At the same time my battery voltage gage stopped working and the needle just sits on the peg on the 8 amp side. also, at the same time my o/d light went off and the o/d cancel switch does nothing. could some wires have crossed? is my auto climate control unit bad? could the plug have come unplugged from the back of the unit partially? crossed wires maybe? i removed the 10 amp fuse from the panel in the a/c location, but nothing changed. any help or suggestions would be greatly appreciated. thanks a lot.
-94MN1246
P.S. i have an aftermarket head unit and a trans temp sensor/gage if it matters (i'm thinking it may be an electrical issue)
-94MN1246
