I have an issue with my V8 when I accelerate hard it feels the car is really pull to the Right almost like I lost traction but no squeeling, no nothing I have to counter steer to keep it on the road. I have an open rear axel on the bird is this the issue? It doesnt happen with my SC. It only happens under HEAVY acceleration like flooring it getting on the highway. Anyone have any clue?
Overkill Fetish Freak
I would check you rear wheel bearings. Put the car on jack stands and grab the rear wheel and see if it is loose. The bearing ($30-$60) is pressed into the hub/knuckle and usally if it is real bad you will need a new hub ($100) as well. The job is not hard but you will have to take the entire spindle to a machine shop to have the old bearing/hub pressed out and the new setup pressed in.
The passenger side is the power side so it normally goes first.
-Scott
