I was going thru the drive thru at taco bell tonight and it kinda wanted to die. When I stopped and had it in drive the rpms would drop to about 500-400, the oil guage would drop almost to the red, and the check guages light comes on. It wouldnt die but it seems like it was trying. It only happens once in a while. Which is kinda confusing. When I put it N or P it would idle right back up. Also, sometimes when im not moving and I turn the steering wheel it will do almost the same thing but not as bad. Any ideas?????
Discussion Starter #2
I also noticed that my crank seems to wobble a little. Could my balancer be failing? Could this be one of the reasons? When I was doing the HG job to my SC, I was turning the crank to move the lifters. I decided that it would be easier to use a breaker bar and socket fitted over the crank bolt. When I tried to turn it, It started to tighten up alittle more without much force. Maybe my bolt is loose?
3rd Gear Chirper
MAF?
IAC valve?
Fuel filter?
Check those first. I have no experience with an SC but that's what I'd look at first. Somebody else will probably chime in also with more ideas.
