1 - 20 of 26 Posts
This is the cost of the minimum that is required to get this engine working in your car. (94-95)
Engine: $1154
McQuay norris parts: $32.41
Ford Parts: $421.04 (Gaskets EGR tube, Fuel lines etc)
= $1607.45
Which is damn good for an engine swap.
Hey dude, I sent you a PM.. IF you have a time, hope you can answer.. About the fuel lines, do I need to change them to 96-97 ones??? Why cant I use the ones we have???
the 94-95 lines will not reach the fuel connectors on the 96-97 fuel rail. And you cannot bend them that far. You could have found this discussed a million times had you searched.
touchy arent we.......
hstang said:
Remind me never to ask you a question.
Uhhh, touchy one, He wasn't being rude, he was simply stating for you to USE THE SEARCH FEATURE!!!! B/c if you do that, you save server space and don't waste ppl's time...I have been told the same thing, and you will find SEVERAL articles on what you are asking...don't take it so personally...
Sheepish
Think you could share on the particular parts you had to buy from Ford, and what are the McQuay parts?
Real Ultimate Goatse Hunter
I'd just like to point out you can make the 94-95 lines work, just don't kink them while bending them. :rolleyes:
Sheepish
Is there enough room or a practical way to put a tubing bender on them to bend them to the proper positions?
There isn't room to fit a wrench in half the places you need to do get half the **** off you might need to, but after enough cuts you can finally get anything in place :) But yea i'm sure you could get a small bender in there, although where you want to bend it I dunno.. you gotta kinda fold it back on itself.
Eleventeenth Gear Poster
I win :D
2002 Aluminum Explorer motor (Shipping included) $1,370.00
Front Cover Gasket F1AZ-6020-A $3.60
Front Cover Gasket F1AZ-6020-C $3.60
Valve Cover Gasket F6AZ-6584-AA $14.76
Valve Cover Gasket F6AZ-6584-BA $14.76
Front Seal for in the Front Cover F5AZ-6700-A $6.08
Exhaust Manifold Gasket XW7Z-9448-AA $22.71
Exhaust Manifold Gasket XW7Z-9448-BA $33.66
Intake Manifold Gasket YL3Z-9439-BA $8.66
Oil Pan Gasket F4AZ-6710-A $25.09
Oil Filter Adapter Gasket F6AZ-6840-BA $5.78
Total $1,517.36
I do not even want to know what I have in mine and I really do not wnat to know. I just know it is not done yet! That is also my fault for changing my nid too many times!!!!:confused:
Discussion Starter #14
Aaron K. said:
I win :D
Total $1,517.36
I said for a 94-95, we need additional parts. Try reading the original posts all the way through before you shoot your mouth off.
...billabong you going to get your car to the track or is there more stuff you want to work out before you get some times?
Discussion Starter #16
I've got some sort of Vac/exhaust hissing I've gotta fix.
I'm gonna drive down to florida and have dennis tune her with an 02 GT MAF.
I've got some suspension and brake work too. It'ss probabaly be a while before she sees the track,
Palmguy said:
After having gone through this I would not recommend bending the lines.
Most people wouldn't, but its not about that. Its about people claiming you can't, when you actually can and its not really that hard.
I think you need to chill out buddy. I guess you missed the :D in my post....have any idea what that means Mr. Personality?
boring............ $1500 with no mods (96/97)
1 - 20 of 26 Posts
