I have a 1994 LX T-Bird it has every otion in the book accept the remote key less entry. I would like to install the ford OEM rather than cutting into or splicing into the Harness is this possible to do?
Possible? Yes. Reasonable? No. You will have to swap the entire body harness which starts in both doors, run to the dash, then down both sides of the body, across the car in front of the rear seat, and then back into the trunk on both sides of the car. It's a huge harness and it's not an easy swap by any means.
what keyless entry aftermarket that is do you recomend is the Viper one decent unit?
