1 - 20 of 23 Posts
Alright guys, well I found out my rear anti sway bar is cracked pretty badly. I am planning on getting an addco model from Summit Racing as they come as a whole kit , now I have a 3.8 might have some mild add ons. Should i go for the 1 1/4bar or the 1 3/8's bar. The front bar will probably stay stock. I read some old posts and saw things about stress cracking, and lots of oversteer with the bigger bar? Need some help as i put in a hold order at summit for the bigger bar for tomarrow. any input appreciated thanks!
when i put in a 1.25" rear bar it didnt up the oversteer just slightly...not enough to crash or change your driving habits...but enough to put a smile on your fact taking a corner very hard ;)
i left the front stock as well
hmm so i'm guessing i'll get a bigger smile with the 1 3/8? lol they are the same price as the 1 1/4 so i am tempted :rolleyes:
Fry Rice Specialist
swaybar is not the thing that bigger is better type.
good point, thats why i'm asking all of you guys what you think, what has worked, what has not, and what you suggest using.
i cant seem to find it, but mark did a really good write-up on the different sizes and how they affected steering. maybe someone knows what im talking about and will post it up.
Installed the 1 1/4 sway bar, its a completely different car, amazing! I love it!
I'd save tons of money and go with 89 SC bars (1.2'' front and 1.1'' rear). Both of those will make a monster difference over your 1.06'' front and 1.04'' rear.
I got both bars for less than $100 shipped (two different people unfortunately, so shipping killed me). Compared to both addcos which will run you about $300 shipped.
I'll tell you what, best $150 i put into the bird yet, its almost like a go-kart! Amazing what one suspension part will do
What if i have sport swaybars? Would the 1 1/4" swaybar still make a fairly noticeable difference in body roll? Thanks alot
Just check the thickness...you put thicker bars on and it's going to make a noticeable improvement in your handling. I went with the SC bars which saved me a couple hundred bucks (enough for a set of Eibachs) and it does a bang up job. It's not like I take S curves at 70 mph anyway...my tires suck too much and there's too many cops around.
SO from when i'm reading i should not install the 1-3/8 bar cause the front is stock
i got a 1 3/8 bar but the front is stock should i not install it and
get a 1 1/4 for my MARK VIII LSC
thanks for the input guys
Resident drifter
I have the 1 3/8" rear bar with the stock front one. I plan on eventually installing the 1 1/4 front bar, but for now the setup has no problems. most cars push pretty bad stock, ours as good as it is, is no exception. stiffening up the rear of the car will help the car rotate in the center of the corner better. by keeping the front softer you allow the tire to bite into the road better, making the car pivot on the front. It does loosen up the car and make it quite a bit stiffer though.
Heavily Medicated Crime Fighter
The 1 3/8" rear bar with a stock front bar will give you a fair amount of oversteer that is why I have recommended that the largest rear bar with a stock front bar is the 1 1/4". I am the person solely responsible for the R&D of these large bars with ADDCO in the first place so I know what I am talking about. If you want the best handing setup and don't mind a little stiffer suspension then go with the F/R 1 3/8" combo. That is the setup I run and would not change it for the world. Using a 1 3/8" rear bar and a 1 1/4" front bar will give you close to the same understeer setup we have in the stock F/R configuration. Matched bars are the only way to go except for the 1 1/4" rear bar and stock front bar which will give good results on its own. MN12s have lots of understeer designed into them. ADDCO MN12 large bars are been available since 1998.
Where's the best place to buy the Addco bars?
ADDCO for the most part only deals with businesses but as a member of the club you can order directly from ADDCO. The prices on the page listed above are a little out of date but not by a hell of a lot. This club had an exclusive on the large bars for over two years when they first came out so we were the only game in town.
1 - 20 of 23 Posts
