1 - 20 of 23 Posts
Hi:
One of the next projects I'm considering tackling on my 24 Hours of Lemons car is to upgrade the gear set to a 3.73 gears on the cheap. Right now, I believe it's a 8.8" 3.27 open diff.
I read recently here that I could possibly salvage the ring and pinion gear set ("the gear set") from an Explorer.
I believe trying to salvage the Posilock or whatever traction lock would NOT be worth the additional effort & cost for my application.
Q: Do you guys have a summary of what years and what models I should be looking to salvage the gear ratio from? I know that if it says its a posilock, I should skip it. Any other suggestions? If you give me ONE model/year of explorer that had 3.73 gears, I'm sure I can dig out of rockauto the other ones and reply back here.
Q: What else can I salvage from the explorer rear end? I think the Explorers use 31 vs 28 axle splines so i can't just exchange the entire pumpkins as one would do with a Mark VIII's rear diff, right?
Thanks in advance for your replies.
-g
The problem with using the explorer diff is that it is a solid rear axle, so the side gears aren't beveled to allow the circlip to compress and slide out. If you put a diff from a solid axle into an IRS car, once you slide your axles in you will never get them out, so even if the spline count is the same, you still can't use it. If you want a trak-lok diff, the best bet is get one out of a SC, then rebuild that with the explorer gears, and you'll be good to go.
Thanks for the explanation on why I cannot use an explorer diff.
So, if I just want to swap out the gearset for 3.73 open gears, can you guys point me to cars/trucks/ranges that had this model?
Dorman apparently only makes 3.55 differential ring and pinion gearsets
Looking at the Motive catalog, I found TWO part numbers: one for the standard gears (crosses with OEM) and one for their premium line (crosses with Ford Racing).
Motive# F8.8-373
OEM# E4TZ4209A
Motive# F888373
Ford Racing# M4209F373
I'm still using google fu to figure out which cars came with the E4TZ4209A by FROM THE FACTORY. Any suggestions/leads here?
-g
MOTIVE Says these are the possible compatible vehicles.
AEROSTAR W/4.0L 90-97
BRONCO 83-96
CAPRI V8 86
COUGAR 80-97
E150-E250 83-99
EXPEDITION 97-ON
EXPLORER 91-ON
F100 81-90
F150-250 81-2002
F150 (F) 97-2002
FORD® 1/2 TON (F) 97-ON
FORD® 1/2 TON (R) 83-ON
FORD® 3/4 TON (R) 83-89
FULL SIZE CAR 80-ON
MUSTANG V8 86-ON
RANGER W/ 4.0L 83-ON
THUNDERBIRD 87-97
At the yards you can just check the axle code and compare to the list above.
Yes I could but I'm trying to narrow down the list PRIOR to wandering all over a yard.
I'm sure SOMEONE has pulled some used 3.73 gears off a car that works in tbirds.
Can anyone let me know what car those gears came from?
-g
The gearset and the differential are separate parts, and can be swapped independent of each other. If you are sure you already have an 8.8 diff and you want 3.73s, go ahead and pull them from an explorer. Double check that though because most V6N/A birds came with a 7.5" diff, and if that is the case, you will need a complete 8.8 pumpkin, or you will need to get a set of gears and a trak-lok unit for a 7.5, which would mean looking for either 83-86 tbird turbo coupes, or late 80s/early 90s ford rangers. If you want a trak-lok unit, the only ones that are going to be a direct bolt-in swap are ones from another MN12, or from a 99 Cobra Mustang if you happen to find one of those laying in the junkyard. There were no cars out of the factory with 3.73s and a trak-lok and IRS, so as far as finding a complete pumpkin to drop out of one car and reinstall in another, it pretty much isn't going to happen. However, with all that being said, the easiest and cheapest way to accomplish 3.73s and a trak-lok would be to pull a set of gears from a low mileage explorer, and a complete pumpkin from an SC, preferably from a manual trans car because they had 2.73 gears, which only one guy in Georgia wants, and he apparently already has one, so you can generally pick them up cheaper, then you swap the explorer gears onto the SC trak-lok unit and into the SC housing, and swap the whole housing into your car, and once completed, nobody will be able to tell you've done anything.
preferably from a manual trans car because they had 2.73 gears, which nobody wants
Don't say that, I keep a 2.73 pumpkin on my shelf for road trips. Couple of hours to swap out the pumpkin as a whole, a few bucks worth of gear oil, and bam, instant 30mpg's, lol.
There, fixed.
Discussion Starter #14
Well, I think I'm going the cheapest route to begin with and will forgo trying to add traction lock for now and am just considering the 3.73 gears. Yes, I'm positive i have an 8.8" rear end vs. a 7.5" one.
I did find something else interesting in my research
3.73 Ratio gearset
41 teeth on ring gear
11 teeth on pinion gear
3.27 ratio gearset
36 teeth on ring gear
Q: Does this mean that the pinion gears are identical between the two ratio gearsets and I can just pick the one in best condition to keep in my car? Or, are the pinion gears different sizes/diameters but just happen to have the same number of teeth?
-g
Aww come on now man thats just mean lol. I thought it was a great idea personally, you guys can laugh at me if you like, I'm ok with that. :D
Hey, whatever you have to do. I loved my 2.73s in my 89 XR7, I just wouldn't consider it worth it to swap TO a set of them. But yeah, for long drives, there is definitely something to be said for cruising at 80mph and 2100rpms getting 31mpg.
3.73 Ratio gearset
3.27 ratio gearset
-g
No, the gears are completely different. The tooth pitch will not be the same, and if you put a 3.73 ring gear in with a 3.27 pinion, you will probably destroy both gears. Not only that, but even within a gearset, they are matched together, so if you take a 3.73 pinion gear from one set and a ring gear from another, it will probably go together, but it will also probably make a lot of noise and not last very long.
Discussion Starter #17
Mike:
Thanks for the explanation. I was hoping I could mix and match here but oh well. So I need to confirm that the donor gear set a friend is allowing me to potentially swap with is for an open diff (vs. Posilock or whatever fancy LSD name there is). That should be as easy as cracking open the rear diff and seeing how complicated it is inside :)
-g
Whether its trrac lok or not doesnt matter. The gears will work as long as its from a 8.8
Oh I agree, I wouldn't ever intentionally build a rear with 2.73's on purpose, no. But keeping one around for the infrequent and long road trips I take from time to time, seems like a good idea to me. Like you said, 80mph and 31mpg's is nothing to sneeze at especially in today's $4 a gallon gas market. And for the OP, like they all said, you can grab any 8.8 gear set and build your rear from that. But they have to remain a set, mixing and matching pinions and ring gears won't get you far. You might could do that if you had a bunch of brand new never run sets laying around, but not with used ones. When they wear in, they are mated for life. I mistakenly bought an Explorer IRS rear thinking I could swap in the diff and gears, well I learned that wasnt possible, so I ended up with an expensive gear set and nothing else I could use. But the gears worked just fine, and are currently in my car working great and making no noise.
Discussion Starter #20
Hrm, I thought the pinion gear looked different in a TL set. I guess I'll figure that out after I tear into this spare differential I've been offered.
One more question, if you folks don't mind:
One Info site recommended that I go ahead and replace the bearings since the set I will be installing was USED and my original bearings+gears have been used for ~130K mi.
When I looked at Motive Product's 8.8" master install kit vs. the standard kit, it lists the front pinion bearing, the rear pinion bearing, and the differential bearing.
Q: For my application (1-2 track days plus the 24 hours of Lemons and a few shakedown ~50mi commutes = call it 2K-3K of mileage total), do I even care about re-using the bearings? If I should buy new ones, do I need to swap out just the pinion bearings, just the diff bearings, or the full set?
Thanks in advance for your tips.
-g
1 - 20 of 23 Posts
