can anyone give me a how-to to adjust the MLPS on my 95 v-6? The transmission is acting up and I have to get it solved before I burn up the clutches. Thanks.
Refrigerator Raider Hater
put the car in neutral, put on the parking brake, crawl under and see if the mark in the white center lines up with the neutral mark on the case of the sensor. To adjust you loosen the screws holding the sensor, and twist the sensor till the marks line up. Then tighten the screws.
