1 - 2 of 2 Posts
Is there any way to get rid of the fuel pressure regulator can that comes with the kit. Can you bypass it and use a regular FPR if the car has been tuned? Im trying to clean up under the hood and would like to get rid of that eye-sore if possible.
Thanks for your thoughts.
On Probation
yes you can get rid of it you do need to build a bracket to support the degasing tank. I did it on my bird when I had it tuned. Just run a vacuum line to the manifold so it will see boost
1 - 2 of 2 Posts
