So I installed a PI intake in my 95 bird and everything runs great until the engine warms up, then it has trouble idling. Sometimes dying when I go to put in in gear. I think I hooked the vac lines up right: back of plenum to the tee on the firewall, and front of plenum to PCV? I changed the IAC, and that helped a bit. I also shot some starting fluid at the various gaskets hoping a raise in idle would show a vac leak, but none did.. Anyway, being that it only happens when warm I'm thinking EGR? What are your thoughts?
Thanks
- Mike
Also, when its idling like that, it sounds good from outside the car, but almost exactly like a diesel from inside the car. Even the gf commented on that..
Thanks
- Mike
