1 - 13 of 13 Posts
I think I've figured it out after trouble shooting with my dad and arguing over some other stuff.
He told me about the valve stem leaking oil, this got me to thinking, couldn’t it technically drip to the spark plug and the spark plug would have to burn off the oil before running well?
It all makes sense too! I've heard that Luca's Oil Additive could fix this problem; I'm not too keen on pouring stuff into my engine though.
How much would it cost at a shop to get my Valve Stems replaced? (If that's even correct, maybe a valve stem?) I’m pretty sure this isn’t a do-it-your self project.
Eric M. Pelezo
The valve stem is part of the valve - you probably just need to replace the valve stem seals, and not the valves themselves.
Chapter Director Coordinator
yep, valve stem seals are the issue on these cars with burning the little bit of oil
happens all the time
cost at a shop? a lot of money heh... the head(s) needs to be disassembled, and by the time you spend money for that, just put a damn low mileage PI motor in and call it a day
hehe, maybe I'll save up for a new used long block.
I'm looking for power. I'm not too sure on some of the stuff too, such as, overbored.
I think I know why forged pistons and what not are more powerfull.
The Band, not the Disease!
The valve stem seal is a seal that goes onto the valve stem, it slides down the valve and seats on the guide. Keeping oil from getting between the valve stem, and the guide. In airplanes... sometimes you want to have a little oil get past there... helps lubrication. of course only some continental motors have them on there, and it's only the exhaust valve. 4.6L has 16 of em. They are cheap too... a shop WILL be expensive, only because of labor. Parts for the job will be seals, and some misc gaskets and a spring compressor, etc etc.
dude go on green leaf and get an 02 explorer motor, around 1000 and it is lighter a good upgrade over our engines
My stepdad owns a shop ;) He's currently in the run of putting his 900hp/w/nos engine on his drag boat.
We get to take it out this weekend, I'm hope he has seat belts for that thing hehe.
I figured out what was causing it, after spending dollar after dolar only to find out it was a vacum leak on a little cord that went from the top of the head covers to under the intake box, it's got a little spot that plugs in that goes to the EGR too I think, maybe PCV not sure.
Seems like an extreme fix for bad valve seals. If you're looking to upgrade, then this is good advise. If you just want to fix your car, look into doing it yourself. You would have just as much work trying to replace the engine.
Since we're talking about replacing the valve stem seals on a 95... :D
How difficult is it to pull the valve covers? The driver side looks fairly easy, but on the passenger side it looks like the fuel and A/C lines are really in the way. :2huh:
I have some "oozing" around the bolts holes and I want to replace the seals (which I think can be replaced without pulling the valve covers). But if figured if I was going to tear that far into the top end of the motor, I might as well do the valve stem seals while I'm there. (I have the OEM spring compressors, and an air compressor).
But has anyone actually done this repair? Tips/hints, etc… :thumbsup:
Covers are easy to get off. Get a 8 mm swivel socket, 1/4" drive and you shoud be set. Pull the 11 bolts/studs out bring the cover off, throw a new gasket on, RTV it and put everything back together.
In order to pull the heads, the covers have to come off, so they are doable. Couple of the valve cover bolts are a little tricky though.
8mm or 5/16" 1/4" drive universal socket should be THE most important tool if you ever pull the valve covers off.. especially when putting them back on...
Cool. Thanks for the replies. I just was worried about the A/C and fuel lines making the removal very difficult. :thumbsup:
Guess it's time to order the seals. :D
Make sure you have a pretty lengthy extension as well. Some of the AC lines do get in the way, so the extension makes it pretty handy. I was stuck using a 8mm socket and a swivel, and there were a few bolts that were very tight t get on. I had to loosen them then use my hands to get them the rest of the way out. I think a swivel socket would be able to get them all the way out.
1 - 13 of 13 Posts
