i have a 1993 thunderbird lx the compressor runs R-12 in it but what other kind can i use without having to change the gaskets and seals?
thank you its hot out here lol
Johnny Five is Alive, TCCoAAC Member
You can use Freeze12 and not require gasket change.
http://www.freeze12.com/
I have used it, and it works good, and is non-flammable r12 replacement.
r134a to do a conversion the [correct way] would require 100% system flush, including removing all your existing oils, all new gaskets & o-rings, and recommend a new oriface tube & evaperator..
And since r134a doesn't run as cool as r12, and you have an r12 system, it will not be as cold.
Discussion Starter · #6 ·
thanks for the help i checked unto that freeze12 stuff its acctully pretty good im going to get some soon my t bird is an everyday car but if it wasnt it would have no a/c no power steering nothin but a water pump and alternator haha thanks again
