1996 Cougar 4.6L
I can not find my owners manual, so I need to know if there is a fuse/relay/module or anything else that is related to the 'ALARM' feature that came from the factory.
My ALARM keeps activating on it's own (horn honks and lights flash). Can it be disabled? When I leave the key turned on in the accessory mode, the alarm will stay silent. The only other option is to disconnect the battery.
Can someone please help.
Yeah I think I need help on that too. My alarm sometimes go off without any reason and I have to rush outside and disconnect the battery :(
Problem Fixed! Theft feature disabled.
I unplugged the Anti Theft Module. Car starts and the door locks work with the remote. Horn sounds when lock on remote is pressed twice. Everything is good!
Pictures below illustrate procedure. Hope someone finds it helpful.
Driver side of vehicle
Peel back the trunk liner
Remove 2 black circular plugs that hold the cover tight
Module will be labled. Unplug the 2 plugs going into module
Before reassembly, try starting your engine. It should fire up, mine did. Good luck.
Good Info, Thanks! Montreal, try that and let us know if it solves your problem, too!
I had a short in the trunk lock which caused the alarm to go off automatically when it was armed (30 seconds after the alarm was set, I believe). I unplugged the alarm mechanism from the trunk lock as a work-around. Repairing it seemed like too much of a hassle.
