I have lowered my car with an Eibach Pro Kit and am having troubles getting aligned properly. Does anyone know where I can find what the new specs. for alignment should be after lowering??? Any help would be greatly appreciated!!!
Thanks all. :D
What kind of problems are you having getting the car aligned? Is it just that nobody near you knows how to align an MN12 or what?
No, I'm told it's because after lowering it has more negative camber and they don't know how much to compensate for from the factory spec.
The specs are the same. On some, it is hard to get the camber to come into specs, depending on how low, worn parts, and parts tolerance. Here is the printout of mine using a laser alignment at the dealer.
I had to modify my Kmember to allow more adjustment to get it to align.
Here is some information on what may be needed if you can not get it into specs, and there are no worn out parts in the suspension.
http://members.tccoa.com/393bird/camber.htm
Good luck.
