Will a 01-04 3.8l Mustang alt fit my 97 3.8l? the bolts are straight across like mine, and it looks like it will fit, but i need to be sure.
thanks
Discussion Starter #2
ok, does anyone happen to know the distance from center to center of the bolt holes? is it roughly 7"?
well this is an aftermarket unit. it's 200a HO and i can get it for really cheap. can i make it work? surely i can, right?
ok, i got some pics of the plug
and a better pic of the back
if i get the 01-04 mustang plug it should be simple. where can i find that diagram, and my cars diagram?
Yes,, it fits... I run the same alternator instead of those large 3G units. The new ones are called 6G alternator and feature better stability and less rotaional weight.
they sell the pigtail connectors online for like 14$ or you can simply snip one off a mustang at a junkyard.
Its a direct fit and direct wire swap.
