1 - 12 of 12 Posts
So, last weekend, the family and I went on a trip. Took the truck(97 F150 4x4 4.6L) to San Antonio and back. On the way up there, I noticed at higher speeds(say 80+) the battery light was coming on. No problem, slow down some, light would go off..........back track about a month ago, I noticed in high rpm's that my battery light would come on and then go away as soon as the rpms would drop off.....fast forward to last weekend, on the way home the battery light was coming on again.
So, I tried slowing down, but had to slow down to about 60mph, and the light would go off. But driving that slow sucked! So, I pull over at a gas station, pop the hood to check things out. All seems fine, batttery looked okay, wires and terminals were good, the alternator was not that hot, you could leave your hand on it. Anyway, at idle, the battery light went off...seemed that the alternator was charging....well, the whole way home I would drive for about 30 miles, pull over and let the truck charge up.
Got to about within 100 miles from home, and the light was staying on. I was watching the volt gauge, and it never dipped past the middle of the gauge(which I estimate is about right at 12 volts). So I just kept driving all the way home hoping for the best. Well, we made it.
Got the truck unloaded, grabbed my volt gauge, and checked things out.
The battery was sitting at 12.11 volts with the truck off.
Truck running, 11.98.....bad alternator.
Luckily, I had one sitting around.(came of the bird).
swapped pulleys, bolted it on, charged the battery, started it, and all was good!
Anyway, you're probably wondering where I'm going with this story.
I have heard of people rebuilding their alternators, but I myself have never given it much thought....the only things I could think of, was nah, I can't do that....there has got to be some magic in rebuilding those.
So, I started to look on the net on rebuilding them.
It actually seems pretty easy.
Even the parts are relatively cheap.
So last night, I decided to start taking mine apart.
Here is what I found...
(warning, crappy cell phone pics)
looks like we've got 1 burnt brush that made a groove in the commentator.
So, looks like a new set of brushes and a new commentator is needed to fix this.
Has anyone rebuilt one before?
thoughts?
What people don't know is new new coils are made with a surface hardening treatment on the slip rings. If you resurface the rings, you most likely have cut through this and are now into the softer material. Will this last as long as a new OEM? I don't think so.
Mitch
You just need new brushes and rotor. I think the brass contacts on the rotor look grooved. You may also just throw some new front and rear bearings in it. It was super easy to take apart my thunderbird alternator. You can get a ford 3G rebuild kit + new rotor and be on your way. my $0.02
-Rob
-Rob
sounds like exactly what i need.....
at least i'll have a spare.....no telling how long this old one will last.
spring hill auto electric . com has a 240a Ford 3G upgrade kit for $177(I think)
you don't even need a whole new rotor, just the slipring, and brushes....fairly cheap stuff.
I didnt know the slip ring came off! This is good to know!
-Rob
it does come off, but I don't know how it's done. You can purchase new slip rings, but I think you need some kind of tool or technique to remove it. it also may be different depending on alternator model.
Sorry in advance.
commentator...
A groovy commentator no less. In color. LOL
Couldn't help myself. Carry on.
Darrin
1 - 12 of 12 Posts
