Hey guys, I'll get you up to speed here.
I am having a battery light come on sporadically. It doesn't seem to change regardless if the car is at idle or at high rpms. It just seems to come on and off at random.
Took the battery out and had it load tested and it failed. The car has been sitting for 2 years and the battery was 5 years old so I'm not surprised.
Now I just finished replacing the battery and the problem still exists. I have now moved on to replacing the alternator. This is still the original alternator from 1994 and has about 120,000 miles on it.
I got the alternator off and one of the connectors is cracked and split pretty bad, and the retaining clip is busted.
I am wondering what this wire/connector is called and where I might be able to buy a replacement?
I believe this wire connects/bridges the stator in the alternator. It's just a single black and white wire that ties into the other 3 pin connector that plugs into the alternator.
