i have a 96 bird with a 4.6. i curently have the motor out of my car and was thinkin wile i was in there i should swap over to an aluminum flywheel and was woundering if anyone made one spicific for a 96 thunderbird for a good price of if i could fit one from a mustang on my motor. any suggestions
Do you have a manual transmission or an automatic?
I’ve never heard of an aluminum flywheel/flex plate for an automatic transmission.
Aluminum flywheels are used to replace the steel flywheels in a manual transmission setup because the steel flywheels are usually SO heavy.
just get a performance torque convertor while your in there
Let us know how that aluminum flywheel works out for you with your automatic transmission.
you get mad crazy top end with those things!
my chevelle is an automatic and i stuck a aluminum flywheel in it. it made a little bit of a difference figured if i could get one for a good price why not
BECAUSE THEY DONT EXIST!. the teeth on our flexplates weigh more than the plate itself.
