1 - 2 of 2 Posts
3rd Gear Chirper
Anyone know what the amperage rating of brown 18 Gauge fuse link wire is?
It's used on the wire from the voltage regulator to the battery on my 97. I hate fuse links and would like to replace it with an actual inline fuse, not only because that's what I prefer but the link is pretty ratty looking and I don't really trust it...I'm going to replace that entire circuit when I do my engine bay wiring in a few months.
I put my trusty multimeter on it and the most current I observed there was 3.2 amps, of course varying with electrical demands. Interestingly, this 3.2 amps was observed with the engine off, ignition and headlights on. I think I'll be okay with a 10 amp fuse and 14 gauge wire, but I thought I'd check anyway.
Thanks again!
I don't know that it helps you infer anything but here's one reference I had saved.
Though applies to oranges, the 130 amp 3G alt in my 94 Mustang GT uses a 20 amp fuse on the alternator's sense circuit IIRC.
I like your idea to start small with the fuse and work your way up as needed.
Not much help here but a free bump.
Good luck.
1 - 2 of 2 Posts
