I don't have any pics of it unfortunately. What I did is if you look at the stock mustang shifter handle, it comes up a bit, then goes back at an angle, the curves up again. I cut it in the area where it is angled back, then extended that, then I cut off the part where it curves back up again and cut new threads into the end of it and put a T-handle on the end. The end result is that the shifter isn't much longer than the stock one (if its longer at all) so the throws are the same, but the angle it comes out from under the dash pretty much matches the angled part of the center console towards the front. I needed to cut out a little bit of the floor in front of where the original shifter went, and I needed to remove the VMM and cut a little section out of the console top and remove one brace that goes across the bottom of the dash right where it meets the center console. I had planned to use some fiberglass to fill in where the original shifter came out of the console top, but never got around to it, and I eventually managed to grenade the T45 that I had put in there, so right now the car is sitting in my garage with no trans. Eventually I'll probably get another trans for it, but for now I have my 89 XR7 to drive every day and I am building a 393 for my 91, so the 94 can wait.
As far as cost, I did my entire swap for $1500 including $325 for a tune to shut off the trans controls and about $200 in exhaust work to get new downtubes bent with some high flow cats in them. I did manage to get my bracket for the slave cylinder made up for free for me, but other than that, everything I did could be easily reproduced for the same cost if you shop around.
Mike
