:thumbsup: looks good. I just might do it to tide me over until I shave the handles. Got a brief how to and specs on the LEDs (mcd rating, voltage, & size)?
Hey guys, I've had great luck using the Sylvania Zevo led bulbs you can get at local auto parts stores for around $25.
It uses different leds for the low and the high so you get great contrast, just like factory. It also fires backwards into the reflector so you get a nice even light...
Calling this "exterior " is kind of 50/50, but here goes...
I am in need of a replacement driver's side door latch. Aftermarket seems to not exist any longer for these, and I have had no luck finding wone through an OEM source. Junkyard parts don't exist for these things here in Iowa (rust)...
Not sure if this is the right forum for this topic, but it seemed like the best fit.
I'm thinking about adding a trailer hitch / storage tray combination off the back of my car to carry drag radials and skinnies without completely filling the interior. Doesn't need to be particularly heavy duty...
Hi guys,
I suppose the topic was already raised before but I didn't find any.
The question is: as I suppse windshields and door windows are discontinued, is there a way to get some of those new?
2017 Upgrade to LED Headlights 9007 (97 T-Bird)
About a year ago I converted my 97 tbird to led headlights and they have been great. Now a few of the tiny emitters have failed and I'm guessing it's heat related. Both heatsink setscrews were loose so it probably wasn't transferring heat very...
