Couple of questions, first one how do you remove the power antenna I want to use a shorty antenna and second question, I got the '97 cup holders and was thinking about putting lighter socket above where it says premium sound on the dash where the little slits are, what's behind there?
Remove the passenger side wheel, remove the wheel well liner, remove the antenna bezel with the correct tool, install manual antenna bezel from a less equipped thunderbird, install antenna mast of your choice.
In the slits in the dash above the radio equipment package tag there is usually and interior temperature sensor for the auto climate control, however I'm not sure if there is one there if it was equipped with manual climate since I've never pulled that trim off a manual climate mn12. Also you didn't mention whether you have it or not, but I'm guessing you do given that it's a premium sound optioned mn12.
Ya I have the auto climate control, guess the power point isn't going there
