1 - 12 of 12 Posts
Now that I totally wrecked my antenna screw (tried using a hammer and screwdriver to tap it loose)
Is there a tool available to take it off ? I tried pliers with no luck :mad:
I think I will have to buy a whole antenna set up
Theres a socket kit i believe you can get try doing a seach on google or yahoo i think it will come up
Will when i was taking the fender off the car i noticed that it was just a bolt screw. Could you just un-screw it from the bottom?
ya that holds the mount on the inside, it wont take the whole unit out, you have to take the top nut off to take the whole unit out
-matt-
yeah i remember holding the bottom nut while un screwing the the top off and then again the other way around too.
ok ladies and gentlemen I got the stupid bolt off ... I went down to the hardware store and bought two new sets of needle nose pliers and got it off with some fighting
Ok, ok...i see what your talken about, I went to the junk yard to get an antenna. I see that bolt on top. So you used a needle nose pliers? How did that work?
1 - 12 of 12 Posts
