Well it finaly went out. No O/D ran the codes, checked all the connections and check the solenoids. Drop the pan UHOH lots of shavings O/D band/drum is historeeee. Have a 9,000 mile unit of a wreck going into today/tommorrow I hope. A little confused on some issues a lot of the updates listed for this trans family (accumulator, servo pistons etc) seem to already be in place the lincoln/mercury line as of 97 followed in the rest of the ford line by 98. Is there any particular updates i need to be aware of?? no i'm not doing a "J" mod or shift kit, but i'm adding a cooler. also the mercon vs merconV question or mercon with Ford additives per spec. So confused don't want to do this again in a year
I'd use the merconV and a good cooler. Make sure to flush your cooler as well. What year transmission do you have coming?
Alan
replacing the trans from the 97XR7 with a 97 XR7 trans
