1 - 12 of 12 Posts
try oxyclean. What I do is get real hot water then mix in a scoop (helps to dissolve it), let it cool down and then soak your shirt in the bowl for a while, give it a rub with a soft brush if available. Then rinse thouroghly, then dry. That always works for me with tough stains.
not sure about antifreeze, but this might work.
When getting blood stains out of clothing, use hydrogen peroxide.
you put it on the stain, let it dry, then throw it in the wash.....
....it just might work on antifreeze.
blood stains eh? and how might you know this handy lil fact sir? been doing the "how many bodies can i fit in the trunk" routine? lmao
I've used Goop before to get a lot of stubborn stains out. Seems to work good.
Jay
Try soaking it in Antifreeze. That will get it all the same color and you won't notice the stain.
Battery acid will take that right out :tongue:
Jay
1 - 12 of 12 Posts
