1 - 13 of 13 Posts
1995 bird to 1998 mustang....
both 3.8.
i know the mustang has coil packs. do you just swap the top piece where the distributor goes? Wiring issues?
Where do you live? Some states emissions laws won't allow you to install an older model engine into a newer car.
13's or Mildly Broken
RodeoJoe: [sarcams]Judging by his screen name, my guess would be California :p I could be wrong though[/sarcasm]
RobinCali: There's a guy on SCCoA who put a SC engine in a Mustang (I want to say 95) His screen name is V6Sprout. He might be able to help you. I believe he also posts on Mustang boards including www.3.8mustang.com.
-Andy "Melon"
haha, he moved back to Illinois I think :D
Why would U want an older 3.8 in there?
Selling the good motor?
unless the motor is free, I wouldn't bother. The 98 motor is worth rebuilding, when the 95 motor is not.
JH
that applies to V6's as well as V8's??
(What little I know about V8's dwarf's what I know about V6's)
Basically, just pull the 98 engine out, set the two engines side by side, and swap wiring harnesses, sensors, etc. You'll likely need to reuse a few other pieces from the 98 engine, such as the upper intake. It's a very easy swap to do.
-Rod
The vacuum ports are a little different. You should be able to use the 95 upper intake, but the 98 would make it even easier. I've done the opposite swap before, a 98 3.8L from a Mustang into a 89 Cougar.
-Rod
1 - 13 of 13 Posts
