does anybody use steel wool for body work?
here is the deal. the clear coat was peeling on the top of the bird. i bought some dupli color clear coat in a rattle can last night. i washed the whole car and thought i had all the wax off of the top of the car. well, i was wrong. i sprayed the first coat last night and let it sit. then went back and the entire top of the car was white. so i got some green scratch pads and got the wax/clearcoat crap off, and was back to factory clear coat that has scratches in it now. the whole point of this was to stop the clear from peeling anymore until i get it painted sometime next year. well i took what was left after i washed and dried the car again and sprayed a coat on the top of the car. it looks 100 percent better than it did, but has some rough spots that need wet sanded down before i get more to do the second coat.
sooooo.........................do any of you think it is feasible to use steel wool pads with light pressure, or should i just get some 1200 grit and do it that way?
like i said, this is getting a paint job and some minor body work next year hopefully, so this is semi temporary.
jamie
Street Freekz
I'd go with the 1200 grit.....steel wool pads don't sound to good for a paint job even if it is temporary. Just my .02 though
Uhh, steel wool should never be used on a car like that. I would het some 1500 and 1200 and wet sand it and then buff it out.
yeah, kind of figured that.....just was hoping to find a decent use for this stuff and since i had a project at hand, thought i would throw it out there. oh well, i guess it goes back in the cupboard.
Jamie
