1 - 19 of 19 Posts
I always wanted to get a Hypertech, maybe it isn't worth the money. If anyone has one, I would pay you to make some changes with it. Or maybe we could buy one and share it.
I'm not real sure what it does.... or how much.
:confused: :confused:
it don't run aaahhh w/e
Discussion Starter #7 (Edited)
There are a couple on Ebay now, they are around $300 and you can flash program your OBDII for better shifts and raise the Speed Limiter. If we bought one as a group we could all use it over and over.
FEATURES
(depending on year, make and model)
Hypertech Power Tuning
Tunes the engine for maximum power and performance, plus potential gas mileage improvements
Three-Stage Power Tuning
Special Three-Stage Tuning for Select Vehicles
Dual Fuel Tuning
Lets you choose optimized tuning for 87 octane or 93 octane fuel
Engine Rev Limiter
Extends the engine's RPM range for a wider power band
Cooling Fan On/Off Temperatures
Permits use of low-temperature thermostat for cooler, denser intake charge and lower engine operating temperature
Transmission Shift Points
Optimizes shift points by speed and RPM for maximum acceleration
Transmission Shift Firmness
Firmer full-throttle gear changes for faster acceleration
Top-Speed Limiter
Allows the vehicle's top speed to be matched to the speed rating of factory-approved high-performance tires
Speedometer/Odometer Correction
Automatically corrects speedometer and odometer readings for non-stock tire sizes and/or non-stock rear-end gear ratios (accurate odometer readings are required by law)
Read and Clear DTC's
Digital Trouble Codes – Check Engine Light
http://cgi.ebay.com/ebaymotors/HYPERTECH-PROGRAMMER-96-97-FORD-THUNDERBIRD-4-6L-NIB_W0QQitemZ140108668616QQihZ004QQcategoryZ33597QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
anybody know how to use it and read the numbers?
blah that suck's
Well then, I wonder if we can get the Porky edition and it won't remember which car it belongs to.
How is it going porkster? Slinging the panties around? Fix your lines yet?
Good luck on it, and its funny, as I read all these things you are doing to the car, I remember you saying, its going to be my daily so I am not going to do tooo much to it! Ya, Right, I knew you would keep playing with it.
trust me if you could tune more than on vehicle with it id be sharing with EVERYONE here in so-cal lol
they would loose money if people were sharing tuners.
why do you think it isnt cheap when people send tuners to be unlocked to be used on another vehicle? after all that a NEW tuner would of been cheaper AND faster to your door.
you can however order the specific package from lonnie to allow you to use the xcal2 with other vehicles to tune them, but its not cheap ;)
Well its not a daily driver anymore thats why. the crown vic is now and plus the mods being done to the birdie are to let it drive smoother, cooler, and longer hece why i added the cooler and added handling goodies
the radio works fine now. the fawker doesnt have trac-lok and the rear end peels *one wheel* out too much.
i already got some chrome interceptor center caps on the way and im gonna add a push bar just for the hell of it :D
and yes we know your old :rolleyes:
wow hypertech power programmer i wish i had the bread to help you guys.
97qwikcat hopefully i see you sunday you can give so pointers on my car. Im still a rookie.:tongue:
Discussion Starter #19
those tuners lock to one vehicle the first time its used just like a xcal2. hypertech isnt THAT stupid...
I didn't realize that, I was thinking it would be such a great thing, now I know why they are not cheaper to buy.
1 - 19 of 19 Posts
