1 - 14 of 14 Posts
Found this Dynomax system on Jeggs... Any opinions?
http://www.jegs.com/i/Dynomax/289/17379/10002/-1
Also as a cheaper alternative, I just want to increase the rumble and tone, not necessarily make the car significantly louder. Anyone replace the rear mufflers with something like glass packs?
Brian
I've had it on mine for years now, no complaints. I think a few people have swapped mufflers for something a bit louder. If you want loud, this system isn't it.
I don't want loud.... Just a little rumble.
Brian
It seems to get a little louder over time. I've used it twice. Took 5 years (with no snow/ice/salt) to rot a muffler out, Flowmaster kit took about as long, too.
Dynomax fits almost perfect, but you may need to trim a little of the right rear pipe section to keep the mufflers/tips from contacting the body. Easy fix with a sawzall and good blade. Had to do that both times.
i'm pretty happy with it. It is not loud at all, but a decent rumble.
X2 I have the same muffers and its a bit loader now that I have the true duals :D
And the muffers tuck up under the bumper very nice :)
I've got a true dual system with a mid mounted Magnaflow. It sounded great till I had the other two cats taken off, then it got kinda loud. So recently I had a good exhaust man install a couple of 18" glasspacks at the very back, with SS tips. The glasspacks quieted it back down again, nice rumble but not farm truck loud. The neighbors appreciate it I'm sure. :D
I've been checking out year exhaust lately and have been thinking about doing the same thing. Do you have any sound clips?
Hey Joe..you have this system? I looked at this system also,I'm still researching for my set-up... How it compared to the stock 4.6?.....oh wait isn't your car a V6?
if your car has the 4.6 can I come by sometime and listen to it to compare?
Thanks
Jason
It's a slight rumble over stock at idle, you know it's different. You really don't notice much until you punch it. Yup, V6 but I'll try to help! Meet you at the Bubbling Brook some Sunday!
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i245.photobucket.com/player.swf?file=http://vid245.photobucket.com/albums/gg77/POSSUM61/watermill009.flv">
Thank you Keith Also there is know dome noise with my system :) RobertP a MN-12 Guru believes its because of the 2.5 inch opening at the tips
1 - 14 of 14 Posts
