Need some help please, my brothers car has an AOD, and the cooler lines that run in and out of the transmission leak. We have removed the lines, cleaned them, retefloned them, tightened them back up, and still leaky, leaky. The lines don't have a flare fitting of anysort, and also when you tighten the line, it still moves in and out about an 1/8th inch or so. How can I fix this problem? Is there an O ring in there or something?
Any suggestions will be greatly apprciated.
JUst buy a new set of pop in cooler line fittings or converter it to flare style fittings.
You can get o-ring to fix those fittings ,but I don't know anywhere to direct you to get them. I get them from transtar.
Alan
They used to sell those 'cooler line fitting repair kits' at NAPA but since they're obsolete they might've quit. Consisted of 1 plastic clip and 1 o-ring.
