how do i go about firming up the 2-3 shift in an AOD with a transgo? also, how hard will the 3-4 shift be (in a 3.8) if i were to drill the X and Y holes? i imagine for a 5.0 it will be very hard, but what about the v6's?
Refrigerator Raider Hater
actually, it would be an even harder shift for the v6, since less torque means less slippage of the clutches.
When I put in my TransGo in my AOD with a 5.0 in front
of it I used all the hardest springs och drilled all the holes
to get it to shift as hard as possible...
1-2 is hard at WOT
2-3 is well... It lights up the tires
3-4 you can feel it's not slipping that much
anymore but it's not hard.. instead if slipping for 3 minutes
after shifting (j/k) it slips for 1 second...
But the best is that it's kinda progressive...
Push the throttle a little it shifts kinda smooth..
WOT... Hold on to the steering wheel... :D
//Thyg0d
