Like Titles Matter
SilverFox said:
For 94/95 Mustang
what do I need to make this swap happen?
97 or older should wire dirrectly up correct? IS it the same plug-n-play?
Will I have to change the computer to control the new shift points?
You'll need a new slip yoke unless you want to use the AODE tailhousing. 97 and older works yes, but they are junk. Best to repin your harness and use something newer. Yes, you'll need a tune.
