For your 4.6/5.4. Keep the rear cylinders cool and the coolant flow even at the rear of your engine with this kit. A must for boosted applications. This is new and never used. Chris
$125.00 shipped
2 coolant T's
2 sections of preformed hose
2 coolant head fittings to go in the rear of the heads
8 hose clamps
and a partidge in a pear tree
Are you willing to split this up? The only part I need is the partidge in a pear tree. :D
MaleWhore
is this easy to install? it seems like it
Will this work for 2v engines?
Simple to install, and yes will work with the 2 valve engine as well. Hardest part will be popping out the freeze plugs in the rear of the heads. Chris
MaleWhore
interested... let me know!!!
