I posted on the supercoupe club site but no answers at all.Iv got a 95 sc five speed.Car sat for a month or so and when i decided to drive it no arc at all.I checked the fuse under the hood but its ok.I have never had an issue with it for 7 plus years and without warning nothing.I dont even know where to start can anyone point me a direction?Thanks for any help.
no that what gets me no light on either position firm or auto,no lights flashing at all. if i didnt know better i would say light was out but i am certain the firm ride is not working you can definately tell the difference between firm and soft.And again in say eight years i have not had one problem with it.kinda thinking maybe change the switch and see what happens.
1994 Cougar XR7 DOHC/5-Speed
The switch could very well be it, but it would be stuck on auto in which the shocks will still firm up under hard acceleration, braking, fast turns or any other aggressive inputs the system senses. EVO is integrated into the SCs ARC system too, is the steering is lighter than normal at highway speeds?
I just noticed you only mentioned checking the underhood fuse, did you check the run fuse under the dash as well? The underhood one only supplies power to the relays/actuators, not the module itself.
you know i didnt even know there was a seperate fuse in the car,i will check that today.when i looked at my electrical manual i didnt see one for the arc in that fuse box. i will look again
