1 - 15 of 15 Posts
02 Explorer Pioneer
The bottom band on the LX is black or smoked in 94-95 and red like th pictures above in 96-97
the only difference is the band at the bottom where it says thunderbird is black on 94-95 and on the 96-97 there is no band and the lettering was moved onto the trunk panel above the driver side light, i say go with the 96-97 on a 94-95 car it gives a cleaner look, like porkchop2002's above.
There was a mid-year change on the 96's to brighter LED's.
-Miller
Full Metal
timb said:
The bottom band on the LX is black or smoked in 94-95.......
actually the lx's from 92-95 had the blacked out bottom band, :)
No no... Imeant more the same , in as they bolt right in to the same mounting locations. I wanted the all read lenses so I had 2 choices... 94 / 95 SC, or the 96 / 97 LX (if hey bolted up).
Thanks
Full Metal
they do bolt in the same locations, the only ones that are really different are the 89-91 tails. but 92-97 are interchangeable, just fyi, later'z....;)
Thanks
92-95 SC tails were all the same. just incase you were searching for strictly 94/95 sc and 96/97 lx.
92-95 sc and ONLY 96 LX are the same.
97LX only light up a little oranger shade of red then all the rest. you WILL notice it if you put a 97 light next to all the others.
not lit up they are all the same.
1 - 15 of 15 Posts
