1 - 10 of 10 Posts
I can't seem to find a Yes or No on this.
I have a set of 3.55's with a Trac Loc out of a Mustang with an 8.8, will they work in an 97 Tbird with an 8.8?
I called Jegs they told me yes, I looked it up online and it told me yes, I looked it up on here some say yes, some say no.
Help needed....
I know sometimes the number of splines changes in each application, I believe my F-150 8.8" 3.55 Trac loc is 31 spline, but the one in my Mustang is 28 spline...
"The MN12 8.8 and 7.5 differentials use a 28-spline shaft. The difference between the standard solid axle and the IRS differential is a "Step" (grove) in both differential side gears in order to retain the Circlip (C clip) that holds the Halfshafts in place"
So my question is now, could I take the both differential side gears and swap them for the ones in my car now and make this work?
hmm, makes sense. I aint never done it though...
The 8.8s will swap back and forth between ford setups. There's no difference between any Ford 8.8 gears of a given ratio that I know of.. it's just a ring and pinion. The difference comes in the side gears. Solid axles are retained via a C clip. Our half shafts are retained at the hub. The pumpkin side slides and "snaps" in. The reason the IRS gears have a bevel cut into them is so that with a little bit of prying pressure, you can pop them back out. Solid axle side gears have a step groove cut into them to retain a C-clip that holds solid axles in the housing. The pumpkin side of the half shaft will go in and pop into place.. but you'll have a heckavu time trying to get it back out... more than likely, you would have to pull the rear cover to get the half shafts back out. The side gears, I believe, are interchangeable between same type differentials, swap the step-groove side gears for the IRS gears in a traclok. I'm not sure on if they're the same from open to traclok differnential.
Ford Racing FRPP ring and pinon are not the same quality as Ford Factory OEM.
There is a difference between 8.8 FRONT diffs and 8.8 REAR diffs. The ring & pinions are NOT interchangeable. Factory Ford or FRPP gears are generally accepted as being best quality and easiest to set up. Everyone has their own opinion, though.
No you can't. The side gears for a trak-lok unit are not interchangable with the side gears for an open rear. You need to either modify the solid axle side gears or get a trak-lok unit for an IRS car.
1 - 10 of 10 Posts
